No voltage to the ecu terminal B+
CarlosPTR210
435
Calexico,CA
www.ptr.com.mx
Hi,
To day i try to turn on the engine, but i found that the ecu don't get voltage in the terminal B+, I already check the EFI fuse and its good, 12V, any Idea where i can try to find the problem?
i have the TS manual and electrical diagrams
thank you for your time and full support
best regards
carlos
CarlosPTR210
435
Calexico,CA
www.ptr.com.mx
I found the problem :S one conector from the engine harness, that need to be plug in to the C1 connetor in the engine bay that came from the fuse box, wasnt plug in :S, but now its fix it, tks to all for your time and full support
regards carlos
