no start after 7mgte swap
thebadz32
124
Louisville Ky,
well i did a 7mgte swap in my car and i can get it to start it seems to be getting fuel up to the motor but it doesnt seem like the injectors are opening it is getting spark and ive been messing with the timeing but no start up help asap please
thanks
kotu100
1,899
Easton, Ma
i know its just basics but.....
make sure both cam gear marks are lined up with the rear cam gear plate, at the same time the mark on the crank must be at the 0 mark, all while cylinder #1 is at TDC.
then the CPS must be installed so it looks like this.
6389952
also just for shits and giggles make sure the pins on the cam gears are both in the middle hole on both the cam and cam gear.
if it doesnt start after you've done all of the above, you have a fuel or electronic issue.
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
and be sure to go over the obvious... everything is plugged in such as coils packs, ignitor, all grounds are connected and clearly.. check the fuses
thats a start
-pete
