Hello people plugged in my emanage and got code 49 no ignition pulse. So I pulled it off started the car CEL came on with code 31 but its because the of the emanage. I already did a continuity test all points came out good but I was unable to pull voltage from the IGF. I have no codes and the car runs fine If someone could confirm the pinning from the 4-pin connector on the ignitor I might have that wrong diagram only shows 3-4. Im going to backprobe the ecu see if I can get voltage its just weird :3d_frown:
