How did you test the fuel injectors? Is your fuel pump priming? What is your fuel pressure? Do all of your timming marks line up as they should? Do you have spark? You need 3 things for an engine to run... Fuel, Spark (ignition), Air.... You need to check everything related to those 3 things
