New turbo is finally here... (pics)
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
The greedy UPS driver showed up this morning with a box. The Missus paid him to leave us alone and leave the box here.
When I finally got home and unwrapped it, this is what I found. Now all I have to do is figure out what I need for oil fittings... and how to mount a wastegate actuator.
Oh - and the center section is 1/2 inch wider than a CT26, which will put the compressor outlet 1/2 inch closer to the front of the car. Hopefully my lower hardpipe (or the couplers, anyway) has that much flex... or I'm going to have to cut it down a bit.
Anyway, on to the pics.
BJ91T
810
Baton Rouge LA
looks like the turbonetics bolt on 62-1 i belive i know of 2 people that have run that with great sucess grim where can i find that turbo i have been looking for a while with no sucess.
thanks in advance
BJ
Ps i can get an exact list for an oil line setup for that turbo if you need it a buddy of mine is running it right now.
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
Close - this is the turbonetics bolt on 60-1 hifi. HorsepowerFreaks can get them. I haven't seen much in the way of specs on them yet, this is supposed to be 500 hp capable, which is more than I care to run.
I'd appreciate the oil line setup list, probably make my life a lot easier! :)
89Turbo
804
Portland
you dont by chance have a TurboNetics part# do you, i can get these through work but there catalog sucks/////////
BJ91T
810
Baton Rouge LA
its the same turbo i plan to run except i am looking at the "original" instead of "hifi" due to a 4in inlet on the original.
I will get that list to you asap
later
BJ
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
i wanna be the 1st to ask. what are you doing with that old ct? i know it was blowing smoke, but i am interested in the wheel and the inducer housing. let me know :D
oh and nice better turbo.
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
The old turbo wasn't blowing smoke, it has death whine and won't boost over 3 psi. Pretty sad for a 60-1 upgraded CT, I might add. I stopped driving it immediately, but even so, I suspect that it's going to need all the usual work for a blown turbo, possibly a new compressor cover, definitely a new compressor wheel. The shaft play is pretty bad.
On the other hand, the exhaust side is almost literally brand new, no cracks at all.
Plan is to get a quote on having it rebuilt, and if it's worth doing, go that route and sell it when it's finished. If I can't get my money back out of it that way, I'll sell the remains cheap as parts.
89Turbo - the part number for the turbo itself, or the accessories to bolt it up? I can look up the part number pretty easily, I *think* it's the Turbonetics number...
89Turbo
804
Portland
both :icon_bigg
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
I'm glad to see more than an upgraded CT-26 on this beauty. Hopefully you won't have problems with the boost creep as some people do with the turbonetics exhaust housings.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Nice!
Get the turbine housing ceramic coated before you put it in...really helps w/ radiated heat to the bay. I believe you have a coater in your neck of the woods too...ask for a 2000 deg rated coating.
BTW - Ever go to the Foggy Dew?
91T breezen'
ROMNEY/RYAN 2012
Apr 4, 2005
1,149
NOYFB!
Dave;
Very Nice! Looks like it "will be on",:naughty: if you get my drift,:biglaugh: when I'm up and running again! I have a "beefy" adjustable wg actuator, that might work on it also. 25psi capable,... I think?! It was the one on my GT3076R.:icon_bigg
