new fuel system part
DSGsupra89
http://www.highgearlife.c
Jun 8, 2007
116
West Melbourne Fl
Alright I going buy an apexi system and a fuel pressure regulater want to know which kind fuel pressure regulater should get. I seen one on horse power freaks for around $60 megan racing makes it too. Is that an good one or there any other supra owner uses I think I need this because my car is lacking power or fuel becuase I have change to hard piping and a front mount intercooler with 3inch exhust system with down pipe.:sarcasm:
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
Aeromotive AFPR.
Although the stock system will do if all you've got is a stock CT and hardpipes/exhaust.
Boostedstr8six
I have better SA than you
Near Columbia, the river
Well, is your engine still mostly stock? If you still have a stock turbo, fuel injectors, and fuel pump you don't need to worry about an aftermarket FPR quite yet. More info on your setup will help us help you.
DSGsupra89
Jun 8, 2007
116
West Melbourne Fl
well I also have an after market fuelpump and an hks boost controller and when I sometime at the light alot of smoke come out and then stop if that helps it also have an hks headgasket with arp head studs
Boostedstr8six
If you're seeing blue-white smoke and it smells like oil burning then it could be the turbo. Do you have any oil leaks from the engine?
