New CT26 dyno 573lbs of torque
Suprapowaz!(2)
2,870
San Antonio, Tx.
two-step-n;1858894 said:
i fixed the breakup it was spark blowout i changed the plugs and gap them down. car pulls like a monster now! time to take off alberts reliable ct26 60-1 and make some real power........ we we're just testing the limits of he's ct26 60-1.
Now that you fixed it, and it pulls like monster now why not make a couple of passes down the strip? I for one would to run one of these upgraded ct26's. Especially if you can draw that much power out of them. Dyno numbers are pretty, but dragstrip numbers turn me on. But, it's your car.
Angry7M
Formerly redmaro
Sep 6, 2007
733
AZ
Agree...
Would be nice to see what a ct-26 at his power lever can do.
7MGTEsup
Formerly 'Down but not out'
Jun 14, 2005
614
England
What is the record for a CT26 based turbo at the strip? From the top of my head its a high 11 I think? Would love to see a CT26 based car trap at 120+
te72
Classifieds Moderator
6,602
WHYoming
There is a 77 Celica in the other cars section that you may be interested in... he has since swapped to a Holset (IIRC), but he was making some impressive times on the CT.
IndigoMKII
2,181
Madison, Virginia
My yamaha 450 grizzly probably weighs almost as much as that car. I wonder if a street driven mk3 will ever trap 120+ with the ct..
te72
6,602
WHYoming
Do it like the domestic guys: high compression and high final drive gearing. Should be easy enough (said, maybe not done). :)
Devin LeBlanc
1,830
Las Vegas NV.
I went 11.5 @ 121 with a 57 trim CT26 from driftmotion on 18 lbs. Full weight other than the spare tire. A/C, everything, I had a 10 inch sub in the back too. Final weight was 3780 with me in the car. I wish I had a 60-1 to run I bet it would have done 11.20's at about 124 ish. The night before that run the car made 404WHP 405ft lbs of torque.
te72
6,602
WHYoming
IndigoMKII;1860845 said:
Hmm.. 10.5:1 compression with a 60-1 ct26.. I'd be driving like this:eek3dance so I can watch for flying parts.
All in the tune sir... Miata engines are 10:1 and run boost too. VW direct injection turbo engines run something like 11.5:1 IIRC on the Golf GTI...
Suprapowaz!(2)
2,870
San Antonio, Tx.
This is what I'm saying. You were only pushing 405ft/lb of torque to the wheels and ran 11.50's @ 121mph. I would have loved to see what that 60-1 running 573ft/lb could run... especially after fixing the break up issue. It's kinda odd that he doesn't want to make a few passes to see the fruits of his labor. Unless of course his car will be strictly a dyno queen and never see a real track to back up any of the horsepower claims. Different strokes for different folks.
Apr 4, 2005
365
Tucson, AZ
E85 helps too lol
in for some quarter mile times
Suprapowaz!(2)
2,870
San Antonio, Tx.
I think he made it clear that he's going to take off the CT26 60-1 turbo off and move on to bigger and better things. He gunning for 600+ rwhp. He's not going to the dragstrip.
te72
6,602
WHYoming
IndigoMKII;1861163 said:
Doesn't the direct injection help a lot though?
Oh, very much so. In fact, I dare say it probably wouldn't be possible without it, to run very much boost pressure at that high compression level. However, combine that with direct injection, and beautiful things happen. ;)
slowmedown;1861509 said:
E85 helps too lol
Not to burst your bubble (e85 is well enough documented as a decent performance fuel), but everything I was suggesting was on 91 octane. Granted, you could probably advance the timing or run a bit more boost using e85, but it isn't essential.
IndigoMKII
2,181
Madison, Virginia
So, in conclusion to this thread we've got a few people backing up this dyno run with a sheet to show it. We also have several people who've run upgraded CT's on higher compression and put down around 25% LESS torque but have dyno/track times to back it up.
Something is picking at my brain with this thread..:stickpoke
heyitsdatguy
loser.....
Jan 9, 2007
172
Mira Mesa,CA
te72;1857737 said:
Nice power, but aren't dyno packs (dynapacks?) the ones where you bolt them to the hubs? If so, you have to take into account a bit of loss due to the weight of the wheels and tires you're running...
Either way, get her running right and see what she lays down! :)
Yes, the dyno at our shop reads that way. When people see our numbers most of them don't like it. But its with the weight of their wheels and tires is what most of them don't understand.
Sent from my MB501 using Tapatalk 2
te72
6,602
WHYoming
So the weight of the wheels and tires are taken into account then? Seems easy enough to do, with a scale near by...
7MGTEsup
Jun 14, 2005
614
England
Something don't seem right there, punching your numbers for speed and weight into a 1/4 ET calculator it comes back with 563hp. Or if you put your weight and power it comes back with 108 trap speed.
