New calipers, new rotors, new stainless lines, new pads, new hardware, new fluid.
Car's up on stands, wheels off. I was attempting to flush my transmission by letting it idle in fourth gear and as soon as I let the clutch out I hear this dragging noise, so I shut the car off. Checked out the rear rotors and black scuff marks were visible on the them, but not all the way around. They have 0 miles on them and I'm pretty sure/I] I got all the air out of the lines. I retightened the mounting bracket bolts and slider bolt but that didn't help.
I don't have a rear speed sensor so my ABS doesn't work. I just replaced the ECU so it hasn't had enough time to figure this out yet. The rotors are coated with Zinc to prevent rust also.
When it happed I noticed the caliper moving back and forth, it almost seems like the rotor was warped, but they're brand new...
Thoughts?
Thoughts?
