Need wiring experts for pinning standalone
rhs
147
Dallas
This might be a tall order, but it would be much appreciated if someone could double check my pins. It's an ECU Master EMU. Going from a JZX90 Chaser 1JZ.
This might also be a good opportunity to have on here for future reference to anyone considering the ECU.
Feel free to ask for clarification. I'll do the best I can with my limited understanding.
rhs
147
Dallas
suprarx7nut;2071767 said:
This might be better served in the 1JZ section. :shrug:
Probably. I just figured more traffic goes through this section so the likelihood of finding someone familiar with standalones is greater.
Looks like this is what I'm going with for the pins. I'll report back in a few weeks hopefully when it's all done.
rhs
147
Dallas
So I guess an update. I think pin 9 (ignition switch) isn't needed and is just a signal to tell the stock ecu the engine is being started. Same with the starter motor (pin 79).
Main relay appears to go to to AUX from a forum thread I found.
I think the starting parameters in the ECU make those signal wires unimportant.
