Okay so here is wat my issue is. Taillight circuit which turns on dash, side markers and tails is being controlled with brake light circuit. Here is wat I have found out so far. Using this ----> as a guide to the wire connections I did some testing to see what happend. I first just connected wires to bypass sensor for Tail Light Circuit and everything worked out fine but the brakes. Thats because no Brake Light Circuit was connected. So what I did second was disconnected the Tail Light Circuit and just connected the Brake Light Circuit. Brakes work fine and nothing of the Tail Light Circuit does not turn on including Dash Lights. Then I followed the write up connecting everything as it was supposed to. Now when you brake Dash lights turn on including side markers. SO what I have concluded was some how some way the Tail Light Circuit with the Brake Light Circuit are being intertwined. What im asking from everyone is were exactly do I start to get this intertwine undid and get everything working properly as it should. Thanks for reading and your time
