Just got my rebuilt engine in, all stock electronics from before. Only thing I've done other than a rebuilt engine is Walbro and AFPR. It gets 40psi when I jump B+ and FP.
The car will stumble to start and dies after 500rpm. I had the CPS off one tooth at first but is now set right, and it will almost start for a second then die once I give it gas or reaches 500-600rpm.
My cam gears are straight up, belt is not loose or jumped any teeth.
All IC pipes are connected, same with vacuum lines.
I'm in a hurry to get this thing running, and it just won't fire up completely.
Just went out again, After cranking a few times it got to 500rpm, gave it some gas. It stalled, let out a loud hiss and a puff of smoke from around the intake manifold.
