I was planning on dropping my motor in tomorrow...having issues already...
First, I searched...
This is the first time ive ever done a timing belt.
I followed the TSRM step by step.
So... I installed the new timing belt, making sure all marks matched up, then installed the tensioner and pull the pin.
All the timing marks are lining up..
Then after I rotate the crank 2 rotations as it says the marks are WAY off.
First try: cam marks were on but the crank mark was off by like an inch.
Second try: crank is set to '0' but TDC on the cams is at the bottom instead of the top...WAY OFF..
What am I doing wrong?!!!
Thanks for the help
Thanks for the help
