Okay... are there any signs of upgraded ct12a's other than dropping the downpipe and y-pipe, or turning the boost up to see if she blows... etc?
Also, has anyone with a wideband recorded what their a/f's are while @ a 4th gear pull?? I've turned the boost up to between 13-14psi and in a 4th gear pull my a/f's are anywhere from 10.3-11.1 @ 13-14psi. Is this normal for stock injectors/ecu, or is this an indication of upgraded fuel management/ecu programing? I have searched around and cant find anyone who has reported their results with a wideband.
Can anyone help with one or both of these?
Thanks!
Thanks!
