Need help with FPR and fuel rail.
dunnbeetle
119
Bemidji, MN
I got an aftermarket fpr and it came with everything except an adaptor that screws into the fuel rail....the fuel rail thread size is 12mm X 1.25....i need sumthing that will screw in there and then allow me to clamp a hose on the other side...I dont want to use SS braided line and all i can find is NPT to AN or NPT to NPT adaptors...I've been searching for hours so i decided to come here....can sum1 PLEASE help me! thx.
dbsupra90
toonar
indiucky
yes you need the solex/del orto carb adapter fitting- 12x1.25 on the fuel rail end and its -6 on the outlet. from there, you need the automate 90* fitting w/ hose barb. it uses a 3/8" hose.
cant say i recommend using normal fuel hose from something that high pressure tho. if you dont want to use ss id recommend getting the parker brand 300psi hose or the earl's super stock hose.
the earl's part number you need for the 90* to hose barb is 709167ERL
marc3
canadian blood
Jul 19, 2006
229
quebec,canada
i know this is an old post, but for the other people searching for the part# of the fuel rail adapter, earl's part # is 991945erl
