need help wiring my temp guage!
supraGhost
212
PA
i bought this guage used and the guy said it has everything i need to install it, i jsut need some wiring..... anyhow. i dont have any directions for it so i dont knwo how to install it.
i have one sensor that goes on a hose somewhere (i dont know where)
and the guage has 4 wires. green black red and orange. im guessing black is ground and green shoudl screw into the top of the sensor thing. and one should power the guage and the other one the lighting on it... but im not positive. help please.
ndial2498
Medford
black=ground, red=12v, green=signal, orange=dash lighting i think, will the sensor fit into your thermostat housing thats how my gauge hooked up.
mhopemk3
The CT install SPECIALIST
Jul 13, 2005
762
Jacksonville, FL 32277
Depends on the size of the threads. There may be a spot on the thermostat housing that you can tap for the sensor. IMO that's how I would do it.. Those hose fittings are not going to be as accurate because it is in front of the thermostat.
kwnate
Lurker
Jul 10, 2005
2,725
None of your fucking business
Green is most likely the lighting. You can test it. As for the sensor I'd recommend getting a brass bushing to install it where the stock gauge sensor is in the T stat housing. You can get the bushing from summit.
supraGhost
212
PA
yeah it is a prosport guage and yes there is a white wire. i thought the white was my 12v power?
how innacurate will it be if i just run the temp sensor in the middle of the upper rad hose? because i wanted to get this thign goign tonight and i dont have tiem to send away for parts before the rain comes!! haha thanks guys
Munky
11
Corpus Christi, Tx
hey i got that gauge and now i need to get that damn adapter didnt know which one but i guess the red one now hahah ... might look into that bushing where the stock T housein is at... i ask for help but i guess cause im a new-b noone replied
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
It's really not hard to find wiring diagrams
Prosports website, FAQ's
Q: I lost my instructions how do I wire the performance Series gauge?
A: Black –Ground
Red - 12v ign. power-meaning power when the ignition is on.
White- 12v ign. power
Orange-Headlight switch.
Green - Sender
The above/below wiring will result in white during the day and color (amber or Green) at night.
mhopemk3
Jul 13, 2005
762
^^^ There it is!
Sorry I didn't get to you last night but putting the sensor in the upper hose will only give you radiator coolant temp. IMO I wouldn't use the hose fitting but hey you already have it. It might be better to use that in the bottom hose. :dunno:
Bigdough666
Picture Me Rollin
Apr 4, 2005
367
Corpus Christi, TX
I looked and couldnt find one, any more info on this?
supraGhost
212
PA
really i just need to see if my temp is getting to hot or if it is spiking. will i still be able to see this if i use the fitting for the upper radiator hose?
supraGhost
212
PA
could i just use the sensor off the stock temp guage? and just wire my sender wire right into that?
supraGhost
212
PA
so i figured before i chopped up my hose that i would check to make sure the sender worked.
i heated up some water and dropped the sensor in. i have the green wire wired right to the top of the sensor. the water was hot hot and nothing registered ont eh guage. i left it in a for a few minutes and then gave up.
whats the deal???? why woudlnt it work?
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
Did you drop the entire sensor in the water? Probably only safe for the thermocouple to be immersed...
Are you sure all the connections on the gauge are correct and fully secured?
supraGhost
212
PA
i only submerged it enough to get the thermocouple wet, not the rest of the sensor. and all my other wires are secure, the guage turns on with the key and does its little full range of motion thing when it first turns on with no problems.
maybe i hooked the wire up wrong? it just just smashed it between the two nuts on the top of the sensor
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
That is strange...
Either it wasn't hot enough to register, the wiring is bad, or the gauge or sender are faulty
Are you POSITIVE the sensor wire is secured correctly and all the way, making good contact? Double check even if you are.
lol I know that doesn't narrow it down much, but it's really hard to say from here, you might want to give prosport a call
supraGhost
212
PA
i looked on there website and it looks like there is two wires coming from the sensor.... i only have one. maybe that is the problem?
