Ok....Trying to bleed my brakes. I just got a new master cylinder(after previous attempts). Started bleeding the new master via TSRM instructions. On the down stroke no bubbles.On the up/return stroke bubbles from 1st piston on the master cylinder. Took off car and bench bleed and put back on same problem. What could be causing this ????
