Okay so I finally took my car out for its first drive and she ran great!! Once it warmd up of course :3d_frown: This was Friday Night.
Basically what happens is when I first start the car up from sitting overnight, it runs very rough, will not hold idle unless I feather the throttle and the vacuum is VERY low. Now once it reaches around 160 F or so, I shut the car off, then restart it and within a few seconds it will idle on its own fine and vacuum is around 10 - 12.
I drove it last night (Saturday) when it was like 48 F and the car wouldnt warm up looks like and it ran like dog shit, lean and popping like crazy.
My set up is as follows which may help for diagnoising
BC 262 cams
Map Ecu with Maf eliminated (File runs good with warm temp looks like)
560 injectors
3" Exhaust and DP
NGK Plugs
180 thermostat (which I think may be the problem?)
Its very annoying as the car will not run with initial start up but after warming up it will and with cold weather around the car not runing right will not help
Need some advice guys! Even Mapecu users can chime in, maybe I need some file tweaking?
BC 262 cams
560 injectors
3" Exhaust and DP
NGK Plugs
