okay so i started my build 5 or 6 months ago and well time and money got cut short i need to know if the parts i have are compatable to get the car to run with out a major problem.
here is what i have:
weisco pistons 84mm with 9:1 compresion
full valvterain 1mm intake .5 exahust and cams stage two
rc 550's
lexsus afm
aeromotive afpr
walbro fuel pump
62-1 turbonetics turbo .98 ar
external wastegate with an 8psi spring
now heres the uncertain parts
stock ecu
stock clutch
stock flywheel.
if im nice and gentle on the car and keep the boost low will i have any problems???
any info on this will be great thank you.
rc 550's
lexsus afm
aeromotive afpr
walbro fuel pump
stock ecu
stock clutch
stock flywheel.
