Need help for 1jz swap
Edmundas
27
Klaipeda
Hello i`m planing to do 1jz swap for my 87 mk3 supra. i know that i need to change crossmember to a 89+ and i already have it. but know im thinking will 1jz from soarer will fit in without any problems or will i have to change motor mount or are they all same in 1jz supras and 1jz soarer.
Thanks for help. :1zhelp:
rakkasan
Currahee!!
Fort Campbell, KY
uuuuuggggg, please search.
Get motor mounts from BIC and I'm pretty certain that you'll have to get another oil pan (rear sump). Also, unless you have a R154 bell housing already, you'll need to purchase assuming that you're going/keeping your 5-speed.
You don't have to extent your harness, drill a hole in the firewall. Search for the location and you'll find threads about it.
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
if you just get bic motor mounts sold by bicperformance or driftmotion you won't need a crossmember swap. also a 1j soarer will work like the 1j supra, i have a 1j soarer in my mkIII
