need carburetor help!!
blackturbona
255
kirkland
First off, i know almost nothing about carbs, besides the basics on how they function.
I have a 88 honda accord DX for a commuter, and it started acting up today.
it will idle, but when i jab at the throttle it kinda sputters higher rpms but then falls really low then goes back to idle.
if i fully depress the accel. pedal it will stutter like i described, but then raise up all the way to redline.
i took a look at the carb and the choke plate only opens this far when the throttle is fully pressed.
could there be some linkage that broke? or just a vaccuum leak i need to find? any help is appreciated!!
rebuild, as that butterfly isn't directly controlled by the linkage... or at least use some carb cleaner on it first...
