Nardi Steering Wheel Hub Question
ERA
1,934
any way the wind blows
Hey everyone,
I recently purchased a Nardi wood wheel and was wondering which hub would be the best fit for it. I've learned that Momos won't work (the bolt patterns aren't the same) and was wondering if anyone out there knew where I could get one for a Nardi online.
Getting in touch with Nardi themselves hasn't been all that helpful so I thought I'd post here and ask.
I'm mainly concerned with keeping the turn signal returns and horn (Although I think I've found ways around this one if what's out there isn't plug and play). Also, I like the look of a longer hub so I'm not considering the NRG short.
Thanks!
ERA
1,934
Gotcha. But I still much prefer the look if an accordion styled hub:
ERA
1,934
Off-topic but there's a guy on Instagram who installed a set of these himself and he painted them black and I thought that they looked great!
And I guess painting the dash gloss black itself makes it look even better!
Something to note about these rings however is that they'll probably be a little warped when you get them. I had to do a little bending of the metal to get them to sit right on the gauge edges
ERA
1,934
I just wanted to give an update. So I ended up ordering a Nardi hub from Amazon (from the link in post #9) and now have my Nardi wheel mounted! I guess this hub doesn't have turn signal returns and you would need to modify a few things to get the horn to work but other than that this hub has worked out great for me!
Make sure the part number for your hub is 4302.00.5009. The box will say 86 Tercel but as I've around a few times before, most hubs for Toyota will work between different Toyota models.
Also, thank you to everybody for your input!
