NA-T few questions!
akito
Keep Laughing.You're Next
Jul 31, 2006
1,568
Springfield/Va
I know this topic has been talked over SO many times but I am about to do a 7MGTE swap over to my NA and i have few questions to ask before the final swap.
My motor:
89 7MGE AUTO
Motor Swap from:
5 Speed 7MGTE 89+
My cousin is keeping the r154 so i have to stick to my Auto for now. So i have a list that i will need to purchase prior to the swap.
_89 turbo ECU ( unless i can use the one that is on the car.)
_89 auto trans ECU
_89+ auto engine wireharness ( unless i can use the wireharness on the car and somehow hack to to work)
_ If i use my stock NA tach i will need to do this converson
http://www.supramania.com/forums/showthread.php?t=58639 and get my self an aftermarker boost gauge.
_Another oil cooler. The one on the car seem like it took a dump on me.
That is all i can think of for now. This is my first time to swap over a turbo motor so im not sure how things are done. And the car is from a 5spd over to an auto. Another thing, i think my 89 is one of the ealier 89 so the wireharness may still have them yellow plugs. Where can i look really quick to find out what color are my plugs so i can buy the right harness for my swap.
Thanks a lot guys.
Duy
Murder
I gots teh CARFAX y0!
Jan 26, 2007
7
Clifton, NJ
I've got All Data on my laptop. I can e-mail you the wiring diagrams if you want to use those, but me-thinks a search for the specifics would make your life easier if you browse through someone else's NA to NA-T swap questions.
akito
Jul 31, 2006
1,568
Springfield/Va
I did, there are a few who had done it. But not like in my case where im getting a wireharness from a 5 speed to sawp over an auto. But if who have a write up then i would like to read it. Thanks.
bluedragon17
87 NA-T baby!!!
Sep 14, 2006
382
Vacaville, CA
my vote is talk to JetJock he should be able to help with the wiring issues. IM also doing the NA-T swap and a BHG rebuild at the same time. good luck
