So its all running and I have some questions hehe. I have a pfc fcon and safr. How well does my safr work with my fcon? I know the gcc is made for the fcon but it seems like the adjustabily is not there, like 12% plus or minus at 5 points. So can my safr still make 50% adjustments or will the fcon limit this?
Also when I did the startup for the afr I turned the key to on with only the #2 switch on, set the cylinders and started the car. I waited until full operating temperature then flipped the #4 switch to on. Is this right? And finally does anyone know where I find the users manual in non .pdf format for it? Then I could stop bugging all of you with these questions.
