My POS Supra
AxelEngle
7
Rochester, NY
Well I bought this car (A white 1989 Turbo Targa 5 speed) while I was in Chicago for trade school. I already had an '89 Turbo Targa automatic in red back in NY.
When I bought it:
Shortly thereafter my radiator cracked, so this:
Then I got whacked in mt front right corner (hiding in the back):
Then I started the hear a bad case of rod knock coming on, so I parked it until I moved back to NY, which is when I began my real project. I'm going to break this off into another post.
---------- Post added at 06:51 PM ---------- Previous post was at 06:46 PM ----------
As I promised, the story continues. I removed the bumpers, fenders, hood, and drilled out the front cross member to make my life easier.
Notice this is on an angled stone driveway :aigo:
Beginning:
Here she comes:
Pulling her apart:
Lonely:
Head off:
Block:
Cylinder 6... hmmm?:
I'm going to break it off here again.
---------- Post added at 07:01 PM ---------- Previous post was at 06:51 PM ----------
I see now that it just attached my last post, I wonder if this will do the same.
Cleaning things:
Before:
After:
Before:
After:
That's about all for pictures for now because my phones camera stopped working around that time.
As of right now, the car is getting a set of wiseco forged pistons, 1.2mm metal HG, arp hardware, 1000cc injectors, BC 280 cams if I can get ahold of them, 272's if not, megasquirt, walbro fuel pump, lc1 wideband, I have a BIC 3" DP with divorced wastegate, SS pressure line for P/S, all parts to rebuild shifter, probably a spec stage 5 clutch, lots of other stuff I'm probably forgetting. The engine is being assembled and tuned by BaldTurboFreak racing, a local guy who is a boss at tuning with megasquirt and many others.
The only thing that is going to hold the car back is the stock turbo. That will be upgraded later on.
AxelEngle
7
Rochester, NY
Thank you, probably not, I don't think the red will look good against black and white with the rest of the car. plus they get buried anyways.
Although, I might have the intake manifold modified to face forward with an ls1 throttle body, which would clean things up.
AxelEngle
7
Rochester, NY
dslocal;1559565 said:
how much power do you plan to make once you ditch the CT?
Somewhere in the range of 6-700, I should have specified, I'm going to be running duel walbros
Thank you Dirty Monkey! I'm certainly trying!
AxelEngle
7
Rochester, NY
Well it's been awhile and I see most of my pics are now broken go me. I'm only going to say that, Duane, I'm gunning for you ;-)
A few plans have changed:
Also, I'm now going to be running it all through a 4L80E.
sweaver
70
ny
didn't i see a dyno sheet on roclife under rick's builds? arn't you running on E85? im being lazy i know
