My other wife,LOL!
Divin' Devin
Supra Extremist
Oct 8, 2005
145
Volusia county,Florida
Car was originally purchased from Jon Doward about 3 or 4 years ago.Was pretty much stripped as he was selling it for parts. It turned out to be in better condition than the one I had at the time.So I spent 3 years researching and buying parts as many of us on here.
ENGINE: INSTALL & REBUILD PERFORMED BY GRIP INDUSTRIES
1JZGTE- this engine was completely rebuilt w/all seals,gaskets,etc. replaced.
Replaced the turbos with the ones in the pic below.No shaft play and are running strong @ 14psi.
It has: JZA70R HARNESS(ORIGINALLY WAS SET UP FOR DIGI-DASH)
USDM 2JZGTE cams
Gray powder coated valve covers
NEW OEM VALVE COVER DECAL
3"DP W/y-pipe
HKS COLD AIR INTAKE
HKS dual exhaust
HKS SSQ BOV
HKS EGT
HKS BOOST GAUGE
HKS GAUGE CUPS
HKS OIL TEMP GAUGE (NOT YET INSTALLED)
JZA70 7K TACH
160 MPH SPEEDO
N/A VOLTMETER CONVERSION
FACTORY NEW GAUGE CLUSTER LENS
WALBRO 255 L.P.H. FUEL PUMP
VOODO MECHANICAL BOOST CONTROLLER
GODSPEED 4" INTERCOOLER W/ HARDPIPING
PERFECTLY RUNNING HYDROFAN ASSEMBLY
BATTERY RELOCATED TO REAR SPARE TIRE WELL
NEW OPTIMA REDTOP BATTERY
R154
STAGE 3 CLUTCH W/13lb. CHROMOLY FLYWHEEL
ARP flywheel bolts
NEW CLUTCH MASTER CYLINDER
3.92 REAR END
CAR HAS COLD A/C & HEATER/CLIMATE CONTROL WORK FLAWLESSLY
POWER STEERING WORKS GREAT
ABS HAS BEEN REMOVED (DIDN'T WANT TO WORRY ABOUT 20YR OLD UNIT GOING OUT)
BRAKES WORK FLAWLESSLY
STEREO NOT INSTALLED YET, JUST BECAUSE I LOVE LISTING TO THE ENGINE AND BOV
HAVE ONE I CAN THROW IN IF IT MAKES A DIFFERENCE.
BODY UPGRADES INCLUDE:
ENGINE BAY PAINTED GLOSS BLACK PROFFESSIONALLY
JDM DARK CHERRY TAIL LIGHTS
JDM TRIM '90+
JDM '90 SMOKED OEM TURN SIGNALS
KEVIN M REPLICA SIGNAL COVERS
JDM BUBBLE MARKERS
REMOVED REAR SIDE MARKERS
MKIV OEM FLOOR MATS (NOT THE CHEAP ONES IN PIC)
JDM ELECTRIC FOLDING MIRRORS (THAT WORK!)
90+ NOSE W/HEADLIGHT WASHERS INSTALLED ALONG WITH '88 BADGE
DEMON FRONT BUMPER
'89 CUSTOM HOOD W/ FUNCTIONAL SCOOP
NEW HOOD STRUTS
JDM MKIV RZ SUPRA STEERING WHEEL
SHORT SHIFTER MOD W/MOMO KNOB
NEW TARGA SEALS
ORIGINAL TARGA TOOL
SUSPENSION: (ALL NEW!!)
EIBACH LOWERING SPRINGS
TOKIKO ILLUMI 2'S
ANODIZED BLACK BILLET TEMS SPORT/NORMAL BUTTONS(THEY'LL NEVER FADE)
'92 TEMS ACTUATORS TO ALLOW FOR STRUT BARS
FRONT & REAR CUSCO STRUT BARS
NEW NYLON SUBFRAME SPACERS
MKIV REAR BRAKES, CAR STOPS ON A DIME, LOVE 'EM!
MKIII NEW ROTORS AND CALIPERS, PADS NEW ON BOTH SETS
SUPER ADVAN SA3'S 17"X10" REAR & 17"X9" FRONT
NEW FALKEN TIRES
PICS:
HERE ARE SOME PICS(ITEMS SHOWN NOT INSTALLED ARE JUST TO SHOW WHAT THEY WERE PRIOR TO INSTALL,THEY ARE THE ACTUAL PARTS)
I will add more pics soon.
Divin' Devin
Supra Extremist
Oct 8, 2005
145
It is the HKS dual Drager that was of that time period specificlly made for competition for that car. Yes it is stainless steel. At the time I purchased it, either on this site &/or SF people were stating there were only like 6 in the country. Don't know if the quantity is true or not . If you use the search button you should be able to find some others on here or SF w/ same set up. Mine came directly off a JZA70R that was imported(after market of course). Sounds like no other exhaust I know of. Tame @ idle, violent @ full throttle!
With my after market y- pipe, the only thing keeping it from being a complete true dual exhaust is the 3' section of3" downpipe connecting the split twins to the split exhaust. Glad you guys like it. I'll try to get better pics to put up today for you.
Divin' Devin
Supra Extremist
Oct 8, 2005
145
Moy;1282425 said:
is the cat-back a modified 2jz exhaust?
No. It is specially designed for the JZA70 chasis. I suppose fitting to the engine depends on your downpipe. Sorry for saying it was only for the 1J. I really don't know that for sure ,since there were other engines in that chasis in Japan as well. The pipe routing however was for the A70 chasis.
Divin' Devin
Supra Extremist
Oct 8, 2005
145
Steini;1281854 said:
Do you have pics with the exhaust installed? It looks badass...
Yeah, hope these are a better representation. I would have to put it on a lift to get them any better. I do have a pic stored on my computer of one on another supra. Can't remember who's it is,but his pics are what started my search for mine. I want to thank him because mine are the only set I have ever seen for sale ,before or since my purchase. I suppose you could make a replica from the uninstalled pic, but you won't get that HKS sound without using HKS mufflers. I suppose the Y-pipe and 2JZGTE cams help too. Sounds like an airplane when I'm cruising through town in 2nd gear.
First 3 pics are my car:
These next 2 are the same system on 2 other people's cars:
If anyone notices that these last 2 pics are of their cars, please chime in so you can be properly credited for the pics,& thanks for the inspiration to spend 1-1/2 years looking for mine. These systems were specifcaly designed for our chasis by HKS.
SupraBlur
96
Hollywood, CA
I know this thread is 3 years old but I ran into this pic from Google just wanted to say that this teal 92T was my car (I took that pic) but sold to another member here in 2009. =)
