My build ...
slacker
master mould maker
Sep 24, 2006
123
BC , Canada
www.toyotafiberglass.com
Rollus;2036792 said:
Awsome build, subscribed ;)
Good luck and keep going
hey .. thanks ...
so , with the tranny out again , I needed to make a modification for the speedo cable . plasma cut out the section that was interfering , and used a piece of 2" tube to fit .. should work
slacker
master mould maker
Sep 24, 2006
123
BC , Canada
still not welded as my weekend is over ... but heres where the "cage" is starting
as previously mentioned .. supports made and now tacked into place
and then bent the support struts ....
not welded yet .. so just a rough mock up
