My black widebody MKIII with 2JZ-GTE and V-160
Turbo Skegget
217
Norrtelje
This started out with me just going to change the exhaust system in 2003 but the car hasn't left the garage since. The project grew day by day and now 8 years later I am almost positive it will see the roads again this summer.
The car before the madness begun
New steering wheel
New poly bushings
Shifter location after some welding
Rear end fittet with aluminium bushings
Passanger seat fitted
New Toyo R888s, 245/17 front and 315/17 rear
New pedals with new mastercylinders
Test fitting wheels
Fuelpump and filters under fuelcell
Battery located in the trunk
Fuelcell lid
Driveshaft adapter
RPS clutch
Modifying car to accept new pedals
My race engine getting built
Driveshaft
Testfitting turbo etc.
Stout hood
Modifying the trunk
Painting front and rear suspension parts
Testfitting fuelcell
Testfitting engine, IC etc
Testfitting
Testfitting oilcooler etc.
Modifying driverseat
Testfitting driverseat
Empty enginebay with manual Flaming River rack
Spacers
Testfitting bigbrake kit from Arizona Performance inside 17" rims
Muffler
Aluminium bushing
Spoiler modifications done by Hällzons Båttbyggeri
Finished spoiler by Hällzons Båtbyggeri (not my car)
Testfitting new white turning signals
and testfitting black aerocovers
Widening begun
Albert
May 13, 2009
1,710
Tempe, AZ
which flaming rack did you use? the 5.0 mustang one or the rx7 one?
also where did you get the solid alum bushings? curious cause I make them
Turbo Skegget
217
Norrtelje
Thanks everybody for your kind words.
The alu-bushings I measured and my friend made them, also sold some on Supra-forum here in Sweden.
I used the Flaming River Mustang 5.0 quick ratio rack.
SupraClaou
846
Athens,Greece
Woooooowww. That's a great build thread. Congrats on your efforts to take your mk3 to another level.
Euro Supras rock! LOL. One question though : what rear end/diff will you use? Also what diff gear? 3.7 is the
lowest oem diff on our cars. Maybe you have the rare 3.54 gears.
I did study the installation of the 6 speed Getrag on our mk3 Supras and found out that the only way to get close
to the mk4 Supra turbo manual rear gearing (3.1 export / 3.2 import gearing) is to use if possible :
-V161 Getrag trans (the V161 trans has the first 4 gears longer than the V160),
-3.54 rear diff ring and pinion (the 3.54 is the longest gear we can fit in the mk3 pumpkin),
-Big diameter wheels , rim/tire combo. (like 265-45/17' or 285-35/18' or 295-30/19),
-Built head with cams/springs/retainers etc. for higher revving/redline using a standalone EMS (8000rpm or 8500 should do)
With the above stuff the 1st gear will be very very usefull..like having the stock 3.1 mk4 rear differential !
Turbo Skegget
217
Norrtelje
Regarding the rear-end I have a 3.54 from Mark Williams installed using some part from Nissan Kingcab. Sorry I dont have more info on this than that because I had it made by an rear-end expert here in Sweden. I do have an AEM EMS and 315-35/17 tires so I do think first gear will be ok.
The day you drive it will prolly be the day you have the biggest smile youve ever had!
Good work cant wait to see the finished product on the widebody.
Couple people have installed the mk4 diff.
