My 1jz taking.first in Import Face off`s burnout contest in Tucson AZ
Turbo Habanero
4,229
Tucson,AZ
Found this photo on Instagram
Turbo Habanero
4,229
Tucson,AZ
My car is fully built but is only on 8psi with a T67 and i was using antilag to stay around 5500rpm only using first gear and no line lock. Just stock brakes
te72
Classifieds Moderator
6,602
WHYoming
Tires tell me you might want to refresh your LSD sir...
Also, I feel sorry for your oil temps. :p Nice burnout though.
Turbo Habanero
4,229
Tucson,AZ
Car now has a destroyed trans and as far as the oil temp i dont have gauge so i couldn't monitor it. But all other gauges and temps were okay and i changed the oil today looked a okay =)
te72
6,602
WHYoming
Ugh, sorry to hear that man. I figure though if you're not running an oil cooler, doing that, standing still, in April in AZ (ambient temps around what, 90 yet?), your oil temps probably approached the high 200's... Then again, there's only so much an oil cooler can do if you're not moving... either way, if you want to keep an eye on engine life, have your oil analyzed. Quite fun to look into actually. ;)
