I wonder if I have a problem due to "upgraded" spark plug wires and would appreciate some advice.
here's the story: I have a few simple performance mods, new low resistance MSD wires. New copper plugs were selected and gaped per writeup on this site (but I can't find the specs at the moment).
There are few weird related problems:
1) puzzling intermittent starting problem. Car won't start if it stalls while warm, or sometimes just won't atart warm. Starts and runs great 3 hrs later.
2) timing gun has trouble picking up a signal unless the no 1 wire is perfectly seated in the coil back, even then it seems to miss a flash, though the engine doesn't sound like it is misfiring.
3) car idles and runs well with ignition set to 20 deg BTDC, idles slower but sort of okay at 10 deg. Timing gun has setting for DIS.
4)visually have spark, but it might have missed a few times, when I was watching it, hard to be sure.
5) no evident spark advance when engine check jumper is removed.
Thes things aren't a problem: coil packs and ignitor test fine with DVM tests. Fuel pump seems to be working fine when pinching return line. I checked all the voltage tests at the ECU and all were normal except the AC signal.
Reground cams appear to be timed correctly. Engine runs really great once started, very smooth and powerful across the RPM range.
Boosted to 11.5 psi. Stock coils, ignitor, '89 ECU.
I am willing to upgrade the coils and/ or ignitor if it is likely to help with starting, or go back to stock wires if that is the problem. I hadn't planned a piggyback ECU until I had the car running reliably without one.
What would be the best setup to make this car run reliably as street car?
