I'm getting codes 24,31,32
I know 24 is normal with maft speed density, but is 31? and 32 i thought was for the 7m-ge, which i have but have all GTE electronics??!?!?!
I'm hooking up timing monitor in the morning, already removed the 'r7' resistor just gotta hook up yellow wire on 10pin to g2, but do i cut the harness and connect it, or just 't' into it, or does it matter?
I have wot afr tracking and ptt afr. but I get 'dead' spots where the tunerpro doesn't show 'target afr' and sometimes it goes rich or lean.
Please guys I'm slowly loosing my mind, but the car does run quite well otherwise.
