MKIV valve body in MKIII A340
May 18, 2007
704
Aarhus
What would it take to mate a A340 from a MA70 to a 2JZGTE from a JZA80 and would it be possible to swap over the valve body from the MKIV TT autotransmission without any modifications?
I'm thinking this might be a way to retain automatic transmission without the need for a custom drive shaft and an electric to mechanical speedometer converter.
I have both transmissions inkluding the torque converter from the mkIV
Kristian_Wraae;1590195 said:
I have no idea what kind of valve body is in the mkIV transmission. All I know is that it has electronic line pressure.
Be a 5 valve then, so Yes it's doable.
(I run one here)
How do you intend to drive the PWM solenoids for LP, Accumulator and TC lock?
