I am pretty sure my supra has a bhg. I checked with the local parts house and can't find a metal head gasket to replace it with. Does anyone know where I can find one, and how much do they normally cost?
Quin;1030642 said:No problem.
Out of curiosity, how did you determine you had a BHG? Have you done a compression test? Block test? Oil in coolant/coolant in oil? White smoke? Waterfall sound? What's going on?
88mkiisupra;1030647 said:shooting water out coolant overflow when cold, oil in water, waterfall sound, white smoke on startup, sweet smell in exhaust on start. Pulled head and found evidence of leakage on exhaust side of gasket around the number 5 & 6 pistons, one bad freeze plug, and noticed torque specs were off as a couple of bolts were only hand tight. Having the head checked this week.
IJ.;1031501 said:Usually between the Head and Block
castrol supra;1031620 said:Welp. Call me crazy but in my book pulling the un-infinitley machinable head is a last ditch effort.
I would nearly pull the entire engine before I undid my head from my block.
Some of his reasoning could have been issues with something else. Possibly, but having ALL of them together at the same time is a pretty good indication. And some of what he said just says he has a stock supra. Doesn't make a lick of difference. BHGs are merciless and will strike anyone with a factory or factory spec HG.
So maybe I was wrong. I'm not sure but I sure wasn't trying to get anyone twisted.
