The joint of metal pipe off the heater is leaking.
When I installed the heater core I used a new gasket and put a bit of sealant on the pipe. It must of got tweaked a tad at installation.
Can I remove the clip that holds the pipe together without removing the heater core? I should ask, will I be able to reconnect the pipe and connector without removing the heater core?
I was going to just reseal the joint with RV sealant.
