Megasquirt Info and Links
cruisnhard
SM Member
Sep 27, 2007
236
Waupun, Wisconsin
I am in the process of setting up my megasquirt and am wandering on what type of sensor the gte cps is. I know it can be used with the version I am running, but there are two sensors in the CPS and wandering which on to set up and the name of it. For example is it a hall sensor, or VR?
Others with megasquirt can chime in whenever.
turbo joe
91
Corona, CA
www.turbojoe.com
The MS systems I've worked on have all been Hall Effect.
The easiest way to tell is that inductive sensors have two wires (+/- signal), while Hall Effect sensors will have 3-4 wires...(+/- signal, 12v supply and maybe a power ground).
MK-111
Wigan
the sensors in the 7m cps are vr sensors.
look in the ignition section of the megasquirt manual for nippondenso cas, it explains everything.
p5150
ASE and FAA A&P Certified
Central Idaho
does the MS and stinger have a falling edge/rising edge select option that you can use to determine which you want to use?
skipbarber
2008 Grassroots Challenge
Mar 26, 2008
134
Rockville-ish, Maryland
In for comments on the final result. We're planning on running the MS 3.0 on our MKIII. cruisnhard, since you're near by, would you mind if we checked out your setup when youre done?
gennro
357
Alamogordo, NM
Hey I figured I would contribute to this thread and hopefully get this stickied. I am going to post links for the Megasquirt.
Megasquirt General Information link:
http://www.megamanual.com/MS%20FAQ.htm#whatis
Megasquirt FAQ:
http://www.megamanual.com/index.html
Megasquirt MS2 extra manual and forums:
Forums:
http://www.msextra.com/
MS2 extra Manual:
http://www.msextra.com/manuals/MS_Extra_Manual_Index.htm
MS2 extra Forums:
http://www.msextra.com/viewforum.php?f=101
Cam position sensor related (Nippon-Denso Cam angle sensor):
http://www.msextra.com/ms2extra/MS2-Extra_Nippon.htm
Buying a megasquirt and parts:
http://www.diyautotune.com/catalog/index.php
I have built, installed and wired and tuned a megasquirt on dodge neons before and know the general knowledge on setting them up so any questions arise I probably could find an answer related to your problem. Also and comments or ideas to help make this thread better would be appreciated!
I hope some of this helps!
cruisnhard
SM Member
Sep 27, 2007
236
Waupun, Wisconsin
Right now the car is running n/a with factory ecu. Once wired up it will be running the magasquirt with na-t, 440 gte injectors, and new fuel pump and 3 inch exhaust. I am just waiting on custom lines to mount the turbo to my na block. I also have a gte block in the works for a makeover. I just want the megasquirt running on a known good engine before I switch to the other engine, mainly for breakin of the fresh rebuild. So you may have yours in before I get mine in, but If I have it in and running I will be happy to help with anything I can. Even if it only consist of showing the setup in the car.
Paul
white89turbo402
5
omaha
hi im new here i was just wondering if anyone had a megasquirt map for a 7mge-t with a 60-1 turbo or a map i could use that is similer just wondering?? thanks for the help
