Hello,
I'm having some problem with noise. I get sync loss all over except for idle and at a steady rpm below 3000rpm.
I'm using the stock CPS with shielded wires running from the MS3 box to the CPS plug.
I have:
MS3+MS3X
Stock CPS
Three Bosch 124 modules are controlling the stock coilpack.
Ign. out (running wasted spark)from MS3X:
coil1 (cyl 1 & 6)to ign A, coil 3 (cyl 2 & 5) to ign B, coil 2 (cyl 3 & 4) to ign C
Inj. out (running fully sequential) from MS3X:
Inj A to Cyl1
Inj B to Cyl5
Inj C to Cyl3
Inj D to Cyl4
Inj E to Cyl2
Inj F to Cyl6
I have checked my grounds and they are now fine.
I have tried to ground the G2 sensor together with trigger ground but that didnt do anything. I thought that G1 was getting noise from G2.
Does anyone have an idea on what can be wrong?
Thanks in advance!
I have:
MS3+MS3X
Stock CPS
Inj A to Cyl1
Inj B to Cyl5
Inj C to Cyl3
Inj D to Cyl4
Inj E to Cyl2
Inj F to Cyl6
Thanks in advance!
