max boost?
91Supra313
1,062
Clarksville TN
I have been thinking about getting this turbo setup for my GT Limited but not sure what this turbo maxes out at. I know the stock CT26 does nothing really after 14psi. I have done a bunch of research and gotten nothing but crap answers online with google. Please someone let me know if this turbo would be good for the 7MGTE. I know about the whole supporting mods stuff. I just want to know the max boost this turbo will push.
91Supra313
1,062
Clarksville TN
So does anyone know anything about the T70 turbos? What is the max psi of those? or what psi have people run on those? I know about supporting mods and what not. I don't want to know what goes into making the power for it. I just want to know how high those turbos will go?
blk91
78
ca
max boost isnt relevent and isnt important, What you need to look at is CFM needed to make the power you need and what turbos are effeceint at that level of cfm.
91Supra313
1,062
Clarksville TN
Well, thanks for the reply on the this one but, maybe I'm just not wording it correctly. Let me try this way.
I know the CT-26 can handle right around 14psi before it drops off on the power. What is the limits of the T70? I'm sure people know the limits of the T03/T04. What psi can this turbo put out max. Just like I said before, I don't care about what power it will push. I just want to know if it is like 20 psi or 30 psi.......what is the max psi output with a T70
blk91
78
ca
25-35 depending on configuration of the T70.... keep in mind the volume will increase dramatically . at 14psi a true T70 could make 25% more power then your ct26, what are you looking to do with the car?
