Master key
wooooosh
73
Inverness,FL
When I bought my MKIII it only came with a one sided valet key and a two sided valet key. I've been to two different Toyota dealers with the VIN # and both dealers said toyota no longer carries that key code. Is this true? The valet keys are a pain because I can only use them in the drivers door and ignition. I can only open the trunk with the pop button and I can't open my glove box. Is there a way to open up the glove box with out a key?
Thanks.
shaeff
Kurt is FTMFW x2!!!!
9
Around
the key code is on the passenger side door tumbler, if i remember correctly. :) try looking at that and giving it to them. though, it wouldn't surprise me if they no longer carry the key code.
you could probably get a good locksmith to cut you some keys. key word here (no pun intended :p) is GOOD locksmith. :)
-shaeff
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
I went to Toyota and they didn't even look at the key. They just took my valet key, and made a key that would work in my doors,ignition,trunk, and glovebox. The only difference I noticed was the valet key has two small notches out of the very tip where the main key does not.
92Turbo
hondas suck
Apr 19, 2005
185
NJ
I had some trouble getting a key for my car. What I did was went to a good locksmith, and he was able to make the key by using the code on my door. It took about ten minutes and only cost about 5 bucks for 3 keys.
born2drv
1,199
Burbank, CA
^^^ What he said.... I got a trunk popper installed with my alarm ;)
Another option is you could always get a complete set of locks and keys for the car, I'm considering doing that myself one day because my ignition is different then my doors and trunk.
Jeff Lange
Administrator
4,919
4
Sunnyvale, CA
jefflange.ca
Or just take the ignition one to a locksmith to get it rekeyed.
As far as the master key/valet key. Just go to a locksmith and tell them you'd like a master key, they should be able to decode your key code from your existing key without you needing to take the door apart, and they'll be able to cut a new master key from that.
