MAP Sensor Boost gauge
Deeznuts
80
VA
kool how did u wire it in (parraell or series). im just guessing but i would think if the signal had to go there the boost gauge to get the the ECU it may run differently. I think the digi guage are so much cooler what kinda guage did u get?
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
I made it myself. A computer engineering degree has some benefits......
If the impedance of whatever you are tapping into the MAP sensor is high enough, it won't have a significant effect on the reading to the ECU.
mischief7m
Broke and Lovin It
Sep 13, 2007
507
Central Ma / Cape Cod Ma
so were you able to just tap into it?
or did you have to add a capacitor or something to it to keep the reading the same?
annoyingrob
Boosted member
Jul 5, 2006
2,304
I just tapped into it, as I have very high impedance inputs on the microcontroller I fed the signal to. If you're worried about it, add a 10k resistor in series.
A capacitor would be a bad idea.
