I have an 89 turbo with a MAFT PRO and the timing control is active. My question is: Is there anyone out there using the timing control feature, and how much are you changing the timing as boost and RPM's rise?
dumbo;1394698 said:I have it wired in and runs good, but honestly I'lve never seen if it actually works, and left it at 0. Does your timing control show up on the timing monitor?
teebone;1394703 said:I didnt do the mod inside the maft pro ... so no. But, you can see with a timing light and by just listening that the timing control is working.
turbobob;1397902 said:A quick poll:
Should I change the Pro so that the timing monitor takes the programmed timing adjustment into account?
Let me know your thoughts.
Bob
