I'm finishing up the wiring on my MAFT Pro and powered it up to make sure I'm getting good signals from all the sensors. When I switched to the monitor display and set AFR as one of my displayed items, the AFR displayed didn't match what my XD-16 gauge was showing. Also, when the MAFT Pro is first powered up, it takes over thirty seconds for the AFR to register(long after the LC1 has completed its sensor warm up and is registering AFR). I've wired the LC1 analog output 2(brown) to the 10 pin orange wire, and LC1 analog ground(green) to the 10 pin purple wire. If I disconnect the 6 pin sensor harness from the MAFT Pro and power it up, I get the same AFR value, which leads me to think the wiring isn't correct. I've verified the analog output 2 on my LC1 is working by connecting my multimeter to it and I get 4.95 volts with the ignition on but car not running.
I'm thinking my problem is connecting the LC1's analog ground to the MAFT Pro's 10 pin purple wire. I think both these wires need to be grounded at the same point. The MAFT Pro wiring diagram is sort of misleading in that both these ground wires are shown connected together, but not grounded. Is this my problem? Also, should the AFR show on the MAFT Pro match exactly what is being displayed on the XD-16 gauge? BTW, My LC1/XD-16 combo has been installed over a year and worked flawlessly. I've also verified that the MAFT Pro is configured for an LC1
