sorry about that. the car is 89+ with wisco pistons powder rods, 720 inj 60-1 turbonetics turbo, hks head gasket with arp's. im running version 4.40
Vehicle Select 00
Number of Cylinders 6
displacement 3.00 Liters
Airflow Source 0X00 Select
Manifold Pressure Source 0X00
Density Comp Source 0X00
Barometer Comp mode 00
Frequancy Out Mode 0X04
V out1 Mode 0 Select
V Out2 Mode 0 Select
AFR Source 1 Select
Freq in mode 0
Aux 1 Mode 00
Main Scale - 11 (here is the problem, no matter what I input here nothing changes)
Volts OUt 1 Setpoint 2.45
Volts Out 2 Setpoint 3.53
Afterstart enrichment 2.20
Tune Load Point Low 36.40
Tune Load Piont Mid 100.10
Tune Load Point High 143.00
Freq Out Max 0
Timing Monitor, Base adjust 0.00
Timing Monitor, Correction 1.27
AFR tracking enable delay 1.00 Seconds
FE Smoothing 30
AFR Min TPS 2.40
AFR Min RPM 3008
AFR Min MAP 161.30
AFR Correction Lean Limit 10.00
AFR Correction Rich Limit 18.00
AFR Correction Gain 5.20
AFR Aux % 0.00
TPS Enrichment 1.00
TPS Decay 0.30
throttle Body Size 7
TPS MAP Max 0.00
MAP Enrichment 0.10
Boost Enrichment 1.20
MAP TPS Min 0.80 Volts
MAP RPM Min 1504
MAF Limit TPS Threshold 0.00 Volts
Maf Limit 0.00
Maf Limit/KRPM 0.00 Grams per second
I hope this is everything that you need if you need more please ask.
