Maft pro speed den,570cc injectors, afpr, STOCK fuel pump, deleted fuel dampener,stock turbo, hard pipes and 12x25x3 EM USA inter cooler. dyno jet wideband,@ 5psi. AFPR @38psi without vacuum line.
I am waiting to become a member of there forum for help, but I need to drive so if you could point me in the right direction I would forever be in your debt. I have seen all the threads in the MAFT pro stickies.
First off the problem right now is @ idle when warm the AFR's jump to very lean when main scale is -25. I have to leave it at 0 to drive around town.
then obviously when hitting it hard on the highway like that it just chokes out because of the rich AFR's off the sacle. So I have to adjust it while driving. but sometimes after starting it and having the mainscale in the -12 range it idels rich. then with a blip of the throtle it starts getting all erratic.
The stock pump is only 7 months old, I know the stock pump should not be used a Aeromotive is on order right now.
Second problem, cant connect tuner pro to the maft pro. as far as i know i have the newest software as i did reflash the unit and when it stars it reads 5.3 "i think" I can get the bin off the thing with tpcu and i have that. but it will not connect to tuner pro. I have set it proprley in the
data acq/emulation window. after clicking the connect button it just reads "hardware not found"
I did not buy the unit new so not sure if there is something i need to change to make it run properley.
also i used the resistor network rather than the 2 outputs for HAC,air temp.
I will load the bin on here when i figure out how to. i just got it off the maft pro.
