Hi Guys I own a 1987 Toyota supra and i recently installed the maft pro with 4.8 and followed the quick setup guide and the car started up no problem. i was amazed as to how easy it was to set it up. The motor is a turbo 7mgte metal head gasket and arps. stock turbo, 3' exhaust all the way back, 2.5 inter cooler hard pipes. my question is i connected the maft pro to the tuner pro and was able to download my settings. I downloaded them while the car was off. I was wondering if you guys would be able to let me know if i have everything setup as directed. and what i should change if anything.
Thanks again for all you help!!
TunerPro Bin Data Export
Source File: Tpro4400XDF_ADS.zip
Source Definition: TPro4800.xdf
Constants
Vehicle Select 00
Number of Cylinders 6
Displacement 3.00 Liter
Airflow Source 0x00 Select
Manifold pressure source 00
Load Source 0x00
Barometer Comp Mode 00
Frequency Out Mode 0x04
V Out1 Mode 0 Select
V Out2 Mode 0 Select
AFR Source 1 Select
Freq In Mode 0
Aux 1 mode 00
Main Scale 0.00
Volts Out 1 Setpoint 2.45
Volts Out 2 Setpoint 3.53
Afterstart enrichment 0.00
Tune Load Point, Low 36.40
Tune Load Point, Mid 100.10
Tune Load Point, High 143.00
Freq Out Max 0
Timing Monitor, Base Adjust 0.00
Timing Monitor, Correction 1.27
AFR Tracking, Enable delay 0.00 Seconds
FE Smoothing 00
Boost control TPS Spool 2.50
Boost control RPM Spool 2400 RPM
Boost control TPS Start 3.70 Volts
Boost control PSI Start 5.00 PSI
Boost control DC% Start 10.00 Percent
Boost control PSI Set 10.00 PSI
Boost control PSI Aux 10.00 PSI
Boost Control Gain 4.00
Boost Control DC% Start Aux 10.00 Percent
Boost Control Max RPM 0.00
AFR Min TPS 4.90
AFR Min RPM 3200
AFR Min Load 166.50
AFR correction lean limit 10.00
AFR correction rich limit 10.00
AFR correction gain 4.00
AFR Aux % 0.00
TPS Enrichment 0.50
TPS Decay 0.80
Throttle Body Size 7
TPS MAP Max 104.06
MAP Enrichment 0.40
Boost Enrichment 0.10
MAP TPS Min 0.40 Volts
MAP RPM Min 2560.00
MAF Limit TPS Threshold 0.00 Volts
MAF Limit 0.00
MAF Limit / KRPM 0.00 Grams/Sec
Part Throttle Tracking Idle TPS 0.00
Part Throttle Tracking Idle RPM 640.00
Part Throttle Tracking Idle A/F Ratio 14.70
Part Throttle Tracking Cruise TPS 0.00
Part Throttle Tracking Cruise RPM 2560.00
Part Throttle Tracking Cruise Load 91.05
Part Throttle Tracking Cruise A/F Ratio 14.50
Part Throttle Tracking Lean Load 84.55
Part Throttle Tracking Lean Delay 10.00
Part Throttle Tracking Lean A/F Ratio 14.60
Part Throttle Tracking Gain 15.00
Edit/Delete Message
Constants
Vehicle Select 00
Load Source 0x00
AFR Source 1 Select
Freq In Mode 0
Aux 1 mode 00
Main Scale 0.00
Freq Out Max 0
FE Smoothing 00
AFR Min TPS 4.90
AFR Min RPM 3200
AFR Min Load 166.50
AFR Aux % 0.00
TPS Enrichment 0.50
TPS Decay 0.80
TPS MAP Max 104.06
MAP Enrichment 0.40
MAP RPM Min 2560.00
MAF Limit 0.00
Edit/Delete Message
