cylinder 1 100psi
cylinder 2 120 psi
cylinder 3 110 psi
cylinder 4 117 psi
cylinder 5 110 psi
cylinder 6 110 psi
..decided to do a compression test to try to figure out if valvestem seals were causing blue smoke when shifting gears at high rpm or turbo seals and came up with these results. the first cylinder i tested had the cps connected could this cause such low readings ?
my plan is to put it back together re-time it and rerun compression tests. Do you guys recommend anything else to pinpoint the culprit before i do this ..
p.s i rented the compression tester from autozone one of the orings looks chewed up could this also be the cause? the first one i exchanged didnt have the check valve in it.
thanks
cylinder 2 120 psi
cylinder 3 110 psi
cylinder 4 117 psi
cylinder 5 110 psi
cylinder 6 110 psi
thanks
