87 Turbo with 17x8 G35 wheels w/35mm offset 225/55-17 tires, all stock TEMS suspension.
According to online tire calculator:
The 225/55-17's vary from stock: 17in Tire Difference
Sidewall Height: .44 inch taller than stock
Section Width: Same as stock
Overall Diameter: 1.88in more than stock
Circumference: 5.93in more than stock
Revs per mile: -57 than stock
Do you think the tires are making this happen?
I get quite a bit of "wiggle" in the rear end with any sudden moves of the steering wheel, to the point I'm concerned about control. I've recently had it up on a lift and don't have any major movement in any bushings. I realize the car is 22 years old (126k miles) , but does anyone else experience this?
