Looking for a RHD digital dash part...
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
I picked up a RHD digital dash, which I am in the process of converting to work in my LHD car.
Unfortunately, it's missing some bits. :( Specifically, the little wheel that snaps on the end of the speedo cable.
So, I'm looking for either that bit shipped to Canada, or some tips on how it works so that I can build my own.
JustinGotA1j
532
Chilliwack
Not to thread jack but if anyone reading this thread has the plugs for the back of the digidash I need them. I have all the other parts just need the plugs with wire tails.
LilMissMkIII
That Aussie Chick
Aug 18, 2006
4,110
Aussie Land
If you guys want, I'll have a look at some local wreckers here and see if I can find what you need :)
If there are no MkIIIs locally, I am more than happy to make some calls to Sydney and see if they have it, as I will be up there next weekend :)
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
Girl, you rock. :)
You plug into the ABS sensor on the trans or front wheel then the box outputs the correct signal to the speedo so it's accurate ;)
I did this using a Hall sensor on the front to drive my AVCR as I could never get a good stable signal using SP1 or 2.
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
Ah, gotcha! I thought you were talking about those little gear boxes that change the speed the cable spins.
I need to figure out if this thing wants a voltage, a frequency, a resistance... or god knows, could be anything.
millers
4
Up North
i had mine pulled apart a few weeks back having a look at it.
it outputs a frequency depending on how fast the cable is turning
there are 4 wires coming out of it. 1 is power, 1 is ground, 1 is a signal and the 4th i didnt connect to anything.
on the inside of the box there is a sensor like in the old ball style computer mouse (http://static.howstuffworks.com/gif/mouse2.jpg). the cable spins the disc with the slots on it and the sensor inside picks up the pulses of light and converts them to the electrical pulse the speedo needs.
no idea how many holes are in the disc but if your going to try build your own i can pull mine apart again and have a look for you
Dave: Yep that's the critter.
Not sure if the Digidash uses the stock 4 pulse per rotation sensor or the higher count ABS sensor and this is why we suggested the JayCar box as you can get it perfect no matter what.
