joliroger4;1577379 said:The MSD DIS-4 works great, but is an expensive option. It will work with the stock ignitor, you interrupt the ignition wires between the ignitor and coils. You will however need two tach adapters as well as aftermarket coils/high tension cords. I run one in my truck and ran one in my grey car. Since I went standalone in my grey car I now run two in that car because the car is now direct fire and needs 6 channels. I also have an exra on the shelf for when it comes time to go standalone/direct fire ignition on the truck.
Good to see you kept the truck!!!! Love that thing.
CajunKenny;1577458 said:Fairly certain it's either fuel or spark related.
On my last dyno session, I gained 5 hp and 5 tq by increasing fp 5 psi. Prior to the adjustment, fp was set per the TSRM. Even with the increase, my power curves showed signs of a problem. They were wavey and dipped a bit.
The results of raising the fp left me scratching my head a bit. I have a built fuel system and certainly don't have a shortage of fuel. I plan on playing with fp a little bit more and gapping my plugs down to ~25 thou and see what that results.
Here's my dyno sheets for reference. You can see where power starts to suffer at the higher boost level.
Do you feel it misfire? My car is a distinct miss that can be felt and herd. Only when the boost is high.
