I have managed to abuse my flex-plate enough to have it lossen up.
I guess 30 plus passes at the strip, 8500 rpm shift point,
and shimmed accumulator springs was a bit too much for the stock bolts.
I now have a new ATI flex plate, and ARP crank bolts.
ARP says to use moly on the threads, and torque to 58 ft/lbs.
Or if using 30wt oil, torque to 85 ft/lbs.
I would feel a lot better using loc-tite.
And I guess, use the 85 ft/lbs torque figure ?
Anyway, what are others doing on their crank/flexplate bolts?
And before I here it, Yes, the ARPs will work with my ATI flexplate.
It is much thicker than the stock, and I have bottom tapped the crank holes.
