Lexus LS400 AFM Capacity and Limits on 7m
teamslow
158
New Jersey
Lots of Questions. I did a search. Didn't find anything.
What is the highest amount of boost that can be reached on the Lexus LS400 AFM?
I am sure it also depends on the size of the turbo. So what is the largest size trim turbo that can be used and what is the maximum boost that can be used for maximum efficiency without hitting fuel cut on pump gas (93 octane)?
Are there any advances having the LS400 AFM over MAF Translator?
I know that if you back the adjuster screw out, the higher the fuel cut will be but the leaner the car will run because there is more unmetered air passing through the AFM. 550ccc injector are suppose to compensate for this.
What is the best setting for the adjusting screw? I read that the best setting is screwing it all the way in then backing out the screw 2 and a half turns for the best setting.
Is this true or will the ECU compensate under normal driving conditions no matter how far in or out the screw is? Because I read that the the ECU will compensate for the AFM at normal driving condition without 550cc injectors?
thanks
gofastgeorge
944
Texas
The ECU will not compensate for large changes,
so don't rely on it to self tune a Lexus MAF install.
And if you go to a S-AFC to dial in your fuel curve,
then you don't need to jack with the screw.
And ditto on the 600 HP (720 injectors) range.
Run a MAF Pro, and loose the AFM altogether, and it's restriction.
But it's a lot more $$.......
teamslow
158
New Jersey
RedEj8;983238 said:
I believe the screw can allow more air in so isnt it suppossed to raise the fuel cut a bit?
There is 2 air passages. The top passage is where the honeycomb is. This is where air is measured. The bottom passage is where air bypass screw is located. Air is not measure there because there is not a honeycomb in that area. Someonone correct me if that is wrong.
8,877
teamslow;983155 said:
Are there any advantages having the LS400 AFM over MAF Translator?
Cost.
You should not need any tuning, unless you are using a bigger turbocharger. It can be done with tuning, but why? Get the better device.
turbonator
vancouver
how much approx $ I just opened up my stock afm after incorrectly cleaning it .It is fine now.but maf pro sounds like the way to go
turbonator
vancouver
I beleive your right.I just talked to a guy in San Antonio from ebay about the whole set screw idea.BS the guy who invented it is from Calgary and ya its snake oil he says
bountykilla0118
In Pursuit of 500rwhp
Jul 16, 2005
1,088
Atlanta GA
LOL snake oil … Actually the screw does affect the amount of air that enters un-metered… I will check 2morrow to see if what happens to my A/F ratio at idle when I adjust the screw.
The Lex AFM and 550's is the most cost effective and user friendly setup there is. You could basically put both of them on and your car would run pretty well with 1 or 2 minor changes. You could get a Lex AFM and a used SAFC for less than $350 shipped to your door.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
from what i sean in my life the lex afm can yeild you about 500 to 550 can 600 be done sure it can but it is all about the tune and teh smarts you ahve on building your set up
jdub
Feb 10, 2006
10,730
Valley of the Sun
Bounty is correct...the screw affects the amount of unmetered air entering the system. More unmetered air means you can attain higher boost before you hit fuel cut. Keep in mind the AFM looks at air intake volume and fuel cut is based on that volume. It also will affect AFR to an extent, more unmetered air will push AFR more lean.
