This friday will be the first time I drag race my car after going turbo.. Last time I was at the drags I was N/A automatic with 2.5 inch exhaust and ran a 16.9 @83 mph
Now I am NA-T 7M automatic
Stock 7MGE Block and head (Higher compression and NA Cams)
Driftmotion FMIC and 2.5 inch hard pipes
Stock CT26 9 PSI
SAFC Neo tuned for 11.5 AFR's under full boost
Stock Automatic Transmission
Stock N/A 4.3 LSD
GTE ECU and wiring
91 octane
10 degree's timing
I am hoping to be deep into the 14's and maybe even hit high 13's.. The temperature on friday will be around 50-55F
I might end up running straight open down pipe then I hit 11-12 lbs of boost.. It all depends.. Anyways I would really like to hear what people think I should run I will be spraying the intercooler with Water/alcohol mix before each run to cool it down..
Thanks
Stock CT26 9 PSI
Stock N/A 4.3 LSD
GTE ECU and wiring
91 octane
10 degree's timing
Thanks
